2010 silverado heads and cam
Registered User
hi there everyone
am planning to build my 2010 5.3 single cap silverado and i would like to know which is the best Cam , Heads , LT heards and intake manifold
best regards
best regards
A little more info you looking for an N/A set up N2O???
N/A- my set up was 215 trick flow heads fast 102 mm cam 236/236 tranny used a billet 4l65 with a 4500 stall and 4.56 at the rear ran a best time of 12.0 on hot 80 degree weather
Send your current heads to Texas Speed, have them turned into a 2.5 head (1k)
Run the stock intake if you stay below a 222ish cam
4" cai
3000-3400 converter is ok as a DD imho
3:42-4:10s is good gears for a DD imho
Cams can go from a 212/218 to a 222/226 hell even a 224/230 (i think someone is running that cam already) keep in mind the bigger the cam the more converter, gears needed to help push the motor into the power band. The "best combo" is all in taste of the owner. I DD a 3600 big cam an 4:10s i hated it, but loved it on the track.
Decide how you want your truck to DD, mpg wise, simple crusing, and if you want it as a track queen or a street roller. All this depends on what YOU are willing to put up with
4" cai
cams 98 silverado
07-31-2015 07:36 AM
Offroadunleashed
07-20-2015 02:25 PM
