210/218 Vinci cam question
I've got an 06 ccsb 5.3 4l60 3.23. My question is has anybody run the Vinci 210/218 .551 114 lsa butt kicker and can tell how well it improved your low end torque. As well as how copy l of an idler out had. it will still be on the factory fuel injection system. Is it even compatible with fi. I'll be towing a travel trailer. Thanks
FYI, there's no cam in this world that improves low end torque on a LS truck engine (over the stock cam). That said anyone of the cams you mention will be great for a DD as you don't loose anything down low but you'll gain around 50-60hp with supporting mods.
4.10 gears is a better bang for the buck as stated, been there done that.
Hotrod, that Vinci cam should be great with those mods, no stall needed.
As for how the 212/218 lopes it's all in the tune, I wanted to hear some lope out of it so my tuner kept the idle rpms same as stock and it lopes nicely even with the tvs1900 on top. People asks me all the time if I have a big cam in there haha
