220/224 – 580/581 – 115 cam install
#22
Originally Posted by JimS
Can you post pics of the meth kit? I've never seen one but it sounds like a good bang for the buck modification. I'd appreciate the help. Thanks, Jim
this is all there is to it jim...very simple to install...
#26
Originally Posted by 1SlowHoe
I am curious as to what size injectors are in this truck and the duty cycle at 6400rpm. Did you get that info while at the dyno..judge:
#28
Those are really good numbers for a Mustang dyno,on a Dynojet you would be making at least 20 more rearwheel hp.Did Allen select the cam for you?How much vacuum are you pulling at idle?How much vacuum at a 60mph cruse?
#29
allen has a superflow dyno...allen has installed this cam in a few other trucks w/ good results as well...not running a boost guage with the radix...only on the dyno to see where the numbers were...
#30
Originally Posted by gonzo 6.0
once again another guy to chicken to rev up a exhaust vid clip.If you read the vid rules its in there so folks can hear the full exhaust note.
hehehe...i would have loved to get you a rev but needed some help that i didnt have...coudda just put the camera on the ground i suppose oh well...next time....
