220/224 – 580/581 – 115 cam install
#31
Originally Posted by bud8fan
allen has a superflow dyno...allen has installed this cam in a few other trucks w/ good results as well...not running a boost guage with the radix...only on the dyno to see where the numbers were...
#33
Originally Posted by 1SlowHoe
Is this true of all Dynojets? The one I use has some kind of eddy current load that they put into it. It is supposed to simulate street conditions. This dyno is fairly new so maybe its an upgrade?
#34
hehehe...i would have loved to get you a rev but needed some help that i didnt have...coudda just put the camera on the ground i suppose oh well...next time....
Let me give you a little mechanics tip.No need to set it on the ground.A milk crate or a log or a card board box it could have been set on while you pushed the camera button,opened the door hit the gas ran it up to say 6k a couple times walked back and clicked off the camera.Pretty simple,guys with far less trucks have been able to GET'R DONE.
Just flik'n ya
Sounds great!
#37
Originally Posted by whitt1
What is the intake centerline on your cam?I'm tring to compare the numbers with some other cams from Comp and Lingenfelter.
you have a pm
#39
Originally Posted by slamedboosted&shaved
what else did u ave to put in when u did the cam did the cam need any value train items to support it
