241/243 Heads???
Old 07-18-2009 | 08:55 PM
0235SS93's Avatar
Default 243 Heads???
I plan on a TR224-112 cam going in my LQ9 before winter. I can get a set of 241 heads fairly easy, possibly even 243's. And since I'm gonna have to change valve springs anyways, I figure I might as well swap heads while I'm at it to bump up compression. How will stock 241 or 243 heads affect the hp and tq of my lq9? Will it be worth the trouble? Where in the powerband will the heads help out?
Thanks!
Old 07-19-2009 | 12:47 PM
TVI's Avatar
TVI
IMHO, for the money, on engines with 4.00" & larger bores, L92's are pretty hard to beat. They flow great right out of the box. Have a good valve job put in them & you're set. Also, I would have a custom cam ground specifically for the L92's & the rest of your setup. Just my $.02.
Old 07-19-2009 | 01:24 PM
skyhighsami's Avatar
no title here
No wiser words have ever been spoken
Old 07-19-2009 | 02:29 PM
00Silv4.8's Avatar
If your on a budget for compression (like I was, L92s are NOT cheap.) Do the 243s if you can get em, they flow a little better than the 241s and I believe compression is about the same between the two. Im running 241s and I believe I went from stock LQ4 comp to something like 9.8 or so. No milling on stock height gaskets. Im going to mill them about .030 to get my desired 10.5:1. If you can mill them and you will be good to go
Old 07-19-2009 | 03:57 PM
0235SS93's Avatar
I'm definately on a budget! Doing my own install and tuning, I plan to spend less than $1000. I can get the cam kit for $590, and I found some 241 heads on ebay for $140, but I'd like to find some 243's.
Old 07-19-2009 | 04:21 PM
SincalT/A's Avatar
I got some 24000 mi LS6 243's w/ new valve seals and decked .007 if you are interested PM me.
Old 07-19-2009 | 07:22 PM
00Silv4.8's Avatar
you can usually find some for a couple hundred. Theres a store on Ebay has them pretty reasonable
Old 07-19-2009 | 09:16 PM
BigRedChvy355's Avatar
What is the name of the store on Ebay?
lsxmalibu
09-09-2015 11:08 PM
03regcab sierra
09-09-2015 02:02 PM
axekick
09-07-2015 07:01 PM
sauldgold
07-23-2015 02:15 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: 241/243 Heads???
