241 ls1 heads
Old 06-18-2006 | 04:35 PM
dirt track racer 81's Avatar
Default 241 ls1 heads
my buddy has some 241 ls1 heads he's been tryin to sell me..are these heads worth getting milled and put on my 5.3? whats the combustion chamber on these heads? opinions needed..
Old 06-18-2006 | 04:39 PM
Yelo's Avatar
66.67cc.....you're better off with the stock 5.3 heads
Old 06-18-2006 | 04:58 PM
how much can you mill these with the intake still fitting properly? flow much better?
Old 06-18-2006 | 09:20 PM
Yelo's Avatar
I've seen .045 taken off and the intake still fit right....
With the smaller bore of the 5.3 and the larger valves in the 241 heads you're going to shroud the valves quite a bit....whether or not the extra flow from tha larger valves will compensate for the shrouding that will occur is anybody guess.
I went with the 241 heads because of chamber size and material (stock 6.0 head are ~71cc and I had cast iron heads) but with a 4.00" bore I didn't have to worry about valve shrouding
axekick
09-07-2015 08:01 PM
nrmskate
08-11-2015 03:44 PM
RONIN LSX
08-11-2015 01:03 AM
Denali08
08-09-2015 05:34 PM
Black-Syde
07-06-2015 03:12 PM
