243 heads on my 5.3 07
Old 04-02-2012 | 07:58 AM
Lil brother PI's Avatar
i would do some 411s and only way it will shak is if like said before not instaled right
Old 04-02-2012 | 11:11 AM
chevy_silverado07's Avatar
So the possibility of shaking is there....do any of yal stay in Houston if so anybody know who does Install of 3.73 gears at a good price and quality work....
Old 04-02-2012 | 01:15 PM
splinter's Avatar
Which heads does yours currently have?
https://www.performancetrucks.net/fo...g-info-434396/
Old 04-02-2012 | 01:30 PM
carbongmc's Avatar
The possibility of shaking shouldnt be there at all. If it shakes, or whines for that matter, they arent installed correctly. If they are done to specs, it wont feel any different then how it does now at any speed, concerning vibration. Dont be worried about doing a gear swap. Just make sure who you pay to do it is experienced in it.
Old 04-02-2012 | 05:11 PM
I bought a pair of 243/799 heads off a 08 5.3
Old 04-03-2012 | 12:03 AM
splinter's Avatar
Those 243/799 heads are indeed relatively stout performers…straight out of the box.
Merely asking your existing CH setup to volunteer a wild guess at estimated HP gain!
Old 04-03-2012 | 12:15 PM
La RPM's Avatar
i gained 52HP at the wheels from 799 heads milled .030 and NNBS intake with 30# injectors and 92mm TB... Flaco tuned it for me. Truck doesn't die off after 4500 anymore
this was on an lm7 FBO with TR220 cam and 3200 stall
Old 04-03-2012 | 05:27 PM
Cool I'm just looking for some gaskets and headbolts now and install can begin
Old 04-03-2012 | 09:43 PM
I do have one question man what's the difference between the stock 799 heads off a 08 5.3 then the stock heads of my 07 5.3?
Old 04-04-2012 | 12:24 AM
splinter's Avatar
Somewhere between negligible and substantial. Your 2007 5.3 is factory rated at ~315 HP, yes?
Of course GM’s VVT, AFM and flex-fuel variations are thrown into our Gen III/IV mix - often with essentially the same head.
Note the 243/799 casting numbers denote only a generic pre-machining lump from the foundry, and that several seat/valve/spring iterations ultimately evolve from those.
Not trying to be a dick about it, just don’t want to see anyone throwing good money after bad.
Quick Reply: 243 heads on my 5.3 07
