243 heads on my 5.3 07
#21
the nnbs 07 trucks came with the 799/243 heads
#23
To expand on this. Larger runners, and a larger intake valve. It also has a larger combustion chamber, thus the need to mill them.
#25
I'm curious as to what happens if I put the heads on without that .030 mill?
#26
#28
will lose velocity and yield no gains because of the loss in compression, it's more noticeable down low but if you take the .030 cut heads vs non cut heads, the .030 heads will still make more power than the un-milled heads. they'll be missing that "quench"
