Are 243 heads worth it?
Old 01-07-2012 | 02:37 AM
Vortec350ss's Avatar
I would say they're worth it as long as you find a cheap set as mentioned above. Look at the difference in power between the LQ9 and the LS2 as a good example. its a 50 HP difference. You can credit the intake for 10 of that, the cam for MAYBE 15, and the heads for a solid 20-25. 20-25 HP for $300 is definitely worth it in my opinion, especially when that's power that would be had across the board.
Everything I have seen shows the 243's slightly out flowing the 317's as well. I know its the same port design, but I think the better combustion chambers of the 243 allow for more high lift flow. That means the power difference would be exaggerated when you're talking about a custom cam with .600 lift.
Old 01-07-2012 | 12:27 PM
1989k1500's Avatar
Originally Posted by kr1s
I wanna drop since i wanna go FI
Whats your 5.3 now, 9.5:1? I wouldnt drop it any lower. You're just going to make it a turd out of boost.
Old 01-07-2012 | 01:31 PM
kr1s's Avatar
D: You got a point! Thanks for pointing that out
Old 01-12-2012 | 06:27 PM
La_BigShit0389's Avatar
I say it worth it go for 243
Old 01-13-2012 | 06:07 PM
TURBHOE's Avatar
i have 243's on my tahoe and the power increase negated the drop in compression. so it feels the same if not a touch better than stock. but in boost its a whole different story.
Old 01-14-2012 | 05:16 PM
1FastBrick's Avatar
Custm2500's Rude Friend
to many 's in here .
In stock form there gonna flow roughly the same. You would be better off saving your money or getting a ported set of heads as desert1500 mentioned.
Old 01-15-2012 | 09:39 AM
teamblackandred's Avatar
i put the 243s on my lq4 with a 226/226 cam and loved it. made 396 rwhp and 458rwtq threw a loose converter in my 2wd rcsb i would say hell ya there worth it thats my 2 cents
lsxmalibu
09-10-2015 12:08 AM
BigEd_72455
08-08-2015 05:49 PM
steves86ta
07-28-2015 11:21 AM
sauldgold
07-23-2015 03:15 PM
06 4.8
07-15-2015 08:17 PM
