243 milled 59cc...cr ? lq4
different question but along the same lines, whats the max you can mill 243s or any LS head for that fact? ive searched alot and found one or two that have done .050 & .055 on 862s and also mentioned anything past that might run into intake fitment problems, but then ive read the plastic intake is pretty forgiving..? so who knows of actual info and not hearsay about max milling and fitments..?
Just make sure if you have you guy mill the heads, that he mills the same amount of material off the intake side of the heads, your intake will fit just fit. Hacking .050+ material off a head though with any sizable cam I'd be worried about PTV clearance unless you're willing to flycut the pistons
If you're getting your heads milled, the head side is the only side that gets milled.
11 Second Truck Club
