243's on 5.3
Old 11-27-2007, 05:06 PM
  #51
Truck Sponsor
Wheatley's Avatar
I got new stock replacement gaskets.
Old 11-27-2007, 08:52 PM
  #52
joshua022's Avatar
Will I need to get bigger injectors if i do this swap?? possibly 8.1 injectors??
Old 11-27-2007, 09:11 PM
  #53
FormerVendor
Derek @ EDO's Avatar
I don't think you will, but it would be a nice upgrade for future mods.
Old 11-27-2007, 09:13 PM
  #54
joshua022's Avatar
I need to check with my tuner and see if my injectors are close to being maxxed out yet. If so then I'll get some 8.1s if i do the swap.
Old 11-27-2007, 09:15 PM
  #55
FormerVendor
Yep, check your IDC, most recommend not going past 80%
Old 11-28-2007, 01:08 PM
  #56
dkota1968's Avatar
I have a set of 243s in my basement collecting dust. Now tell me if im right: stock gasket size is .053" and the stock LM7 CC is 61cc. The LS2 heads are 65cc and the ratio of milling .006 equals 1cc on 243s. How far would I need to mill to get a 10.5-1 or 11-1 comp ratio? Could also use a flatter gasket like .041" to help with the smaller combustion chamber.
Old 11-28-2007, 03:52 PM
  #57
Truckshop's Avatar
i don't remember how far you can mill them before you have clearence issues. mine are milled .040 with stock gaskets and if i had to guess my cr should be between 10-10.5. so with a thinner gasket it should be easy to get where you want to be. it would take someone smarter and more precise than me to give you specs.
Old 11-28-2007, 06:02 PM
  #58
dkota1968's Avatar
Ill have to look further, thanks for the reply
Old 11-28-2007, 08:41 PM
  #59
joshua022's Avatar
My buddy has some on his LS1 and they are milled .055 with stock gaskets and he doesn't have any clearance issues.
Old 11-28-2007, 09:03 PM
  #60
TouchOfEvil04's Avatar
sweetness.
Quick Reply: 243's on 5.3
