243's on 5.3
Old 11-30-2007, 07:57 PM
  #71
custom 68's Avatar
I might be
dave
Old 11-30-2007, 08:31 PM
  #72
Truckshop's Avatar
not if i can get them first.
Old 12-16-2007, 08:15 PM
  #73
13 Second Truck Club
trxmxzx's Avatar
well is it a recommended setup?
Im setting up a motor also that consists of running the tr220, LTs, bolt ons, 3200 fuddle stall, and im debating on running the 243 heads (LS6). Was/is there a noticble defference in these heads on a 5.3?
would I have to mill anything?
thanks for the help and info
Old 12-16-2007, 08:19 PM
  #74
joshua022's Avatar
They definetly flow a lot better than the stock 5.3 heads. and yes, you would need to have them milled since their stock combustion chambers are 64-65cc and the 5.3s are a little smaller than that.
Old 12-16-2007, 08:39 PM
  #75
11 Second Truck Club
bluecajun5.3's Avatar
start out with your stock heads first.
get your times, then go from there.
Old 12-16-2007, 08:49 PM
  #76
trxmxzx's Avatar
Alright, its making sense now. thanks on that
how about the pushrod lenght? is that a concern? if I milled them .040 running stock 5.3 gaskets
about the injector issue, 02' injectors are they alright for this also or am I pushing my limits also
Old 12-16-2007, 08:51 PM
  #77
about the injector issue, 02' injectors are they alright for this also or am I puching my limits also
your injectors will be maxed out bud.
Old 12-16-2007, 08:58 PM
  #78
trxmxzx's Avatar
well i thought about milling those to get a little more compression, but then read up a little on the LS6 heads and then tossed the idea around to maybe run them on my motor.
would it be worth it to port the stock heads or run the Ls6 heads though?
Old 12-16-2007, 08:59 PM
  #79
trxmxzx's Avatar
DAMN, what are you running
Old 12-16-2007, 09:04 PM
  #80
joshua022's Avatar
You would be better just running the 243s unless your gonna have the 5.3 heads professionally ported, i wouldn't try it by hand.
Quick Reply: 243's on 5.3
