317s milled to 68cc - p-t-v issues? Pushrod length?
I just need to make sure before I pull the trigger on this. 317s milled to 68cc with a valve job. TSP 228r 112 lsa cam. Of course ptv has to be checked at the time of installation, but theoretically should it be fine? Also, will my 7.40" pushrods be okay, or do I need shorters ones? When I bought the 7.4" I didn't know I was going to be putting on milled heads.
Thanks
Thanks
FormerVendor
I think you should be fine IMO. The fastest and easiest way to check what length pushrods you will need is to get a pushrod length checker from Comp, they are easy to use and cheap and takes out the guess work.
GrooveCityZ71
08-31-2015 12:05 PM
nickpc82
08-30-2015 09:18 PM
BennyB
08-01-2015 08:48 AM
