350 to 383 Stroker question
OK, was originally going to just rebuild my 97 vortec 350, but both heads where cracked so I got new heads, now it looks like I am going to order new pistons also. So my question is to turn it into a 383 stroker, all I have to do is change the crank correct? If so, can someone give me some specs for one? I dont want to spend a crap ton of money on one. I am already into this motor more than I wanted to be, but figured if thats all I have to do and can find one reasonable to me I would go that route.
Thanks
Mike
Thanks
Mike
32 views and no replys? I am trying to seach to make sure this is correct, but I keep getting info on 5.3s, so someones help would be greatly appreciated.
Thanks
Mike
Thanks
Mike
you have to have the block bored .030 over. also have the block massaged so the rods clear the block. speed-o-motive has nice stroker kits also try searching enginekits.com.
FormerVendor
We have Compstar kits starting around or slightly less then $2,000.00
That's the Crankshaft, Bearings (you will need a race bearing) Rods, pistons, rings and locks. Fully balanced ready to rock.
383 = 4.030 bore 3.750 stroke
