370/MP122 Build
Old 09-01-2007, 08:53 AM
  #111
dhpro's Avatar
Been out for a while but here's an update:
Slowhawk at DezRacing is doing the tuning and we seem to be a little lite on power. Currently 415/425 @ 8lbs and 2.9 pulley...it was running perfectly with no issues, but I elected to keep it there and put an underdrive pulley on it and get boost jacked up closer to 12lbs, hook the meth up (and into the washer reservoir), and see if we can't wake this pig up!!! The truck is fighting us every step of the way tho! Pulleys out of stock everywhere, came without spacers, 8" bolt in 6" box , no meth hose available...u get the picture! Power prob cud be the heads (any suggestions welcome) too mild cam, or 4L80 (in fact it might be worth opening that thing back up to see whats ticking, but it seems to work fine) but who the hell knows and after this long I just want it back (and Slowhawk wants an end to the transferred frustration!). It shud be good to go next week and I'll put miles on it for a bunch of months . In the meantime I'm gonna do more research on heads/cam packages I guess!
Please - everyone chime in as I want suggestions. R/
Old 09-01-2007, 09:02 AM
  #112
what a rush!
moregrip's Avatar
what is the build specs on the motor again? What balancer did you go with?
Old 09-01-2007, 09:24 AM
  #113
dhpro's Avatar
LQ9 Block (new) overbore
cam: 214/218 .559/.562 @ 114lc
Heads: RHS ProAction/All Pro - Flow #s @ 1.6 lift
I E
100 66 54
200 136 111
300 196 154
400 246 198
500 276 244
600 291 254
700 289 258
Flowed with a 4.060 bore
Chamber size 66
236 cc intake
Pistons: Diamond custom cut to heads (gonna get volume specs 2day)
Springs: Comp 918
Melling oil pump and remote filter
Dynatech LT's
Eagle Crank
FluidDamper Balancer (see pics on page 1)
compression 9.4:1
**All balanced and bla, bla...motor is solid and once overed by Slowhawk and he says seems well built...what else u need to know? R/
Old 09-01-2007, 09:29 AM
  #114
what a rush!
moregrip's Avatar
an under-drive pulley will spin it slower not faster, is that what you want?
I don't see anything that would indicate a problem motor wise, you sure the valves are closing all the way? (i.e. correct pushrod length)
Old 09-01-2007, 09:30 AM
  #115
dhpro's Avatar
Im an idiot....OVERDRIVE!
Old 09-01-2007, 09:31 AM
  #116
what a rush!
moregrip's Avatar
which overdrive pulley did you go with?
Old 09-01-2007, 09:33 AM
  #117
dhpro's Avatar
Dunno...haven't seen it, all I know is it came from Eastcoast SC...I trust Slowhawk to have chosen wisely.
Old 09-01-2007, 09:38 AM
  #118
what a rush!
moregrip's Avatar
probably an Innovators West piece then, that's where I bought mine. They sent me a bolt that was too short for the damper, anyway I PM'd ECS with the correct bolt and spacer info a while back, I have no idea whether or not they used the data I sent them. In any event if you need the correct info just let me know, it's posted on here I responded to a post Slowhawk made on the Corvette forum regarding your truck but never heard back from him either. Whatever I can do to help
Old 09-01-2007, 09:44 AM
  #119
dhpro's Avatar
I'm banned for CF due to my dispute with CHUCK COW (he's still sitting on one of my PCM's!). Slowhawk's been out most of the week....but we got the pulley without spacers and bolt, now got the 8" bolt sent wedged into a 6" box ...this build has been one serious test of everyone's patience!
Old 09-01-2007, 09:52 AM
  #120
what a rush!
moregrip's Avatar
In case you need the info:
https://www.performancetrucks.net/fo...&postcount=596
https://www.performancetrucks.net/fo...&postcount=598
https://www.performancetrucks.net/fo...&postcount=600
Quick Reply: 370/MP122 Build
