4.8 to 6.0 in 9 hours
Old 10-22-2006, 08:28 PM
  #41
StrokerAce03's Avatar
Where'd you get your engine from? I have a house not too far from Brunswick but haven't seen any engines for sale in my area. Basically I'm looking for somewhere that has parts for our trucks in the south Ga. area. Good job on the swap man; even though you say its easy I think it'd take me 100x as long to do as it did you
Old 10-22-2006, 11:45 PM
  #42
slowec's Avatar
I found it on car-part.com locator website. I took a day off work and drove 5 hours one way to get this baby. It was all worth it. The place was called allpro in Aurburndale, fl. when I say its easy, I mean you can follow the normal instructions for replacing an engine and get these results. Its easy compared to port and polishing heads or building a forged internal motor.
Old 10-23-2006, 09:01 AM
  #43
Bad_Apple's Avatar
You can also check in Hazelhurst, GA. They have two large junk yards there, they usually keep a couple of 6.0L for sale.
Old 11-27-2006, 03:12 PM
  #44
Banned
bluecamaroz28's Avatar
Are the injectors the same in size between the 4.8, 5.3 and 6.0L engines, for someone who might get the long block less intake and injectors?
Will the fuel pump of the 4.8L truck be enough for the 6.0L engine?
Will it run with the 4.8L tune and be okay to drive until it get tuned?
Old 11-27-2006, 03:37 PM
  #45
Nick™'s Avatar
depends on the year, but in general, yes it will work unless you are putting in a cam.
same as above, a 255 lph pump wouldn't hurt anything though
it has been done, I wouldn't get too crazy with it but you could do it, I would advise getting it tuned as soon as reasonably possible and no playing around in it until that's done...
Old 11-27-2006, 03:41 PM
  #46
Banned
It's a 2003 Silverado 4.8L, if it matters.
Old 11-27-2006, 03:51 PM
  #47
Nick™'s Avatar
in that case a 6.0L stock will be fine with your original injectors and pump, but before the other upgrades like power adders and cams come in to play make sure you budget for fuel system upgrades, but in general you should be fine
Old 11-29-2006, 02:56 AM
  #48
Banned
What fuel upgrade if it is cammed only?
Old 11-29-2006, 05:30 PM
  #49
i have a 2000 silverado with a 5.3l...has 130.000 miles on it and a pro charger kit...spun a bearing and want to go 6.0l with the pro charger from the 5.3...i know the supercharger will work and the motor will bolt right in...but what do i do about the computer/ecm?...the truck is 2wd and is lifted 7 inchs with 35x13.50x20 tires and now has a 4.56 ring and pinion.....thanks in advance...
Old 12-12-2006, 10:58 PM
  #50
mercuno's Avatar
O.k. I just got a complete 6.0 with 30k on it. I have an 04 rcsb with 4.8 and built tranny. the 6.0 has everything to run it injectors tb heads etc etc no pcm. you guys are sayin I can just drop in motor and use my 60e reprogram the pcm from my 4.8 and be fine?????? also will it work if I use my 4.8 heads on it and an ls1 intake?????
Quick Reply: 4.8 to 6.0 in 9 hours
