4.8 big cam.
4.8 big cam.
Hello everyone,
I previously had a RCSB with a 4.8 and went with a chopacabra cam and that was purely for CHOP!. Welll long story short I have another truck (RCLB 4.8) and wanted to know if the Hawks Sinister cam is too crazy of a cam for a 4.8 it is a car cam (ls1) at the end of the day. Specs are 230/236 .600"/.600" 112+4 LSA. I plan on keeping the SBE, & hand porting & decking the heads.
If your gears are LOW enough, and your stall is HIGH enough, the short stroke mouse motor will be plenty happy.
My wild-as guesstimate says the 4.8 with 230/236 is crying for 4.56 gears and 3600+ stall
If you plan on 11:1+ compression, 4.56 gears and 4500 stall, then sure go for it. Still pointless though unless you're running nitrous or boost. It's pretty proven that around 220* intake is max needed to squeeze all the power you'll get out of a 4.8L N/A. Basically you're just killing driveability and both low/midrange torque, with zero benefit in peak power.
For example, Summit's SUM-8720R1 218/227 .600/.600" 112+2 made same power as a whole host of much larger camshafts in a 4.8L. (Note: Ignore the title, all testing is without boost).
makes children cry
^^ echoing the above: will it run? sure. is it overkill? probably.
case-in-point: my builder, with concurrence from BTR, recommended a 231/248 cam for my little LS1 (originally speced for a high-effort 6.2). what saves its drivability in my car is its wide LSA (120°+5) maintaining compression... that and pushing 13psi through it.
even then, there was a marked decrease in sub-2500rpm torque (even in my little 3400lb car), but it carries through to 7000 now instead of falling off above 5500.
Yon2xx (Yesterday)
makes children cry
oh yeah... and you'll need to do dynamic compression calculations to see how much more static compression bump you'll need to maintain cylinder pressure.
going from stock 853s (10.1:1 SCR) & 2000 LS1 cam to the bump stick above with ported 243s (10.6:1 SCR), i've still got slightly lower cylinder pressure now despite pushing 2psi more boost.
Yon2xx (Yesterday)
Yon2xx (Yesterday)
Or instant boost from a supercharger.
03_SILVERADO_SLO
07-05-2006 06:59 PM
