4.8 turned into a 5.3???? I need help!!!!
Originally Posted by LVSTOGOFST2002
are you positive on that? from past research i'd like to say you're wrong. But, if you're not, i'd like some info to back it please. My buddy is actually getting ready to do this right now. I'd like to help save him from making a mistake.
that was the chart i had seen in the past..... i see the correction.
Shouldn't the rod to stroke ratio be corrected too then?
Edit: Ok, should be all fixed up and accurate to the best of my knowledge, lol.
Just called the machine shop and he said $180 to punch it out. Yes I want to run a ls6 intake on it for sure and I will probably run it backwards too. I found a 5.3 crank for a $100 bucks and do I need to get stock LS1 pictons and rods and run arp bolts in everything? And you guys would get some 243 heads? What would be a good cam for this setup, I wan't a big lope since this is no daily driver and what stall will I need with the cam?
Thanks guys
Thanks guys
Originally Posted by jkade72
You can run the intake backwards on these motors. Turn the intake 180 degrees and bolt it right up.
http://67-72chevytrucks.com/vboard/s...d.php?t=234761
