4.8 turned into a 5.3???? I need help!!!!
Old 05-21-2007, 08:16 PM
  #21
Mr. Obvious
nightrunner's Avatar
and what does that do besides put the TB inlet in the rear????
Old 05-21-2007, 09:11 PM
  #22
Does nothing. Why do as everyone does and not be a little different?? I think it looks good my self but I probably would not do it on a daily driver.
Old 05-21-2007, 10:11 PM
  #23
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
I have a set of stock LS1 pistons and rods Id let go for 100 and shipping PM me if you want them. Ill even throw in the stock rings
Old 05-21-2007, 10:13 PM
  #24
Tootall's Avatar
you might want to reconsider being backwards, there's no real benifet to doing that
Old 05-22-2007, 01:27 AM
  #25
ZZebes's Avatar
That kinda actually makes me a little sick, why would you do that???
Old 05-22-2007, 02:51 AM
  #26
Tribe Shaman
PappyDan's Avatar
i guess it would depend on some kind of ram air system.
like a working scoop to channel air directly in to the tb.
Old 05-22-2007, 07:38 AM
  #27
One who finially guessed the benefit.
Old 05-22-2007, 07:44 AM
  #28
There is no benefit unless you are doing like my old man (he is pulling air from the cowl). I am going to run mine backwards and have 2 tubes that come back around to the front of the motor with a cone filter on each end. I guess far as looks opinions are like ********, everyone has one. I like the way it looks myself.
Old 05-22-2007, 10:35 AM
  #29
SS_bnoon_SS's Avatar
That's one way to get around the water pump to TB clearance issue when going to a car intake I guess. Next question is, how much clearance do you have at the back of the engine bay in your truck? I looked at mine and I don't see enough room to clear what you're talking about...
Old 05-22-2007, 02:18 PM
  #30
TarheelZ's Avatar
Originally Posted by SS_bnoon_SS
...question is, how much clearance do you have at the back of the engine bay in your truck? I looked at mine and I don't see enough room to clear what you're talking about...
I think he said it's going into a '72 Blazer so he probably has LOTS of clearance.
Quick Reply: 4.8 turned into a 5.3???? I need help!!!!
