4.8 turned into a 5.3???? I need help!!!!
Old 05-22-2007, 03:39 PM
  #31
Originally Posted by TarheelZ
I think he said it's going into a '72 Blazer so he probably has LOTS of clearance.
This wouldn't work in a truck like you guys have but I have a lot of room in the 72 blazer engine area.
Old 05-22-2007, 05:12 PM
  #32
ZZebes's Avatar
i just thought about something, if the 4.8 and the 5.3 have the same bore couldn't you swap the flat top 4.8 pistons into a 5.3 to give a compression bump without milling the heads???
Old 05-22-2007, 05:20 PM
  #33
Mr. Obvious
nightrunner's Avatar
if im not mistaken the 4.8 pistons require to use the 4.8L-specific rods
Old 05-22-2007, 05:45 PM
  #34
rivierakid55's Avatar
this exact same question was posed in last months truckin magazine by a guy with a older blazer too. weird.
Old 05-22-2007, 06:43 PM
  #35
You and me have the same taste in women I see
Old 05-30-2007, 08:05 AM
  #36
What will I need to do to the 4l60e to take a little abuse. I will not drive the ever living **** out of it but it will do a burnout here and there and it will never see a track for sure. The trans on has about 20k on it and it was rebuilt gm trans. How big of a stall will I need??
Old 05-30-2007, 08:32 AM
  #37
ChevyThunder17's Avatar
Transcooler, transcooler, transcooler.
How much does it weigh, what sort of mods are you thinking? I would say a 2600/2800 right off the top of my head. It's one of the smallest converters over stock that Yank sells. If you were planning to go with Yank that is.
Old 05-30-2007, 09:52 AM
  #38
I want to at least run a tr224 cam and I have 3:73's with a 295/40/20 on back which is 29 inches tall. It probably weighs in 500 to 800 lbs less than a newer rcsb truck. The blazer is a full convertable right now but I will run a fiberglass 1/2 top and a aluminum bed cover but it still will weigh less than a truck. If I knew how to post pics I would show what I am working on.
Old 05-30-2007, 10:09 AM
  #39
I don't go by the method prescribed by others, I go my own way. I'm not going to sit here and think about every last mod and try to figure out what will be optimal. What manufacturer are you going with for the torque converter? I was just looking at the Yank SST 3200 myself. Sounds pretty good to me.
Old 05-30-2007, 01:11 PM
  #40
Have you ever heard of the boss hog converters? I have one in my th400 and it seems pretty good.
Quick Reply: 4.8 turned into a 5.3???? I need help!!!!
