4.8 turned into a 5.3???? I need help!!!!
Old 08-03-2007, 04:30 PM
  #51
Tootall's Avatar
the 4.8 will be nice, but you're going to want the big block like power out of the 6.0
Old 08-03-2007, 09:45 PM
  #52
So if I put the crank and rods in it will be a high compression 5.3???? How would it run? I have a th400 and a 2800 stall, what would be the cam of choice??? Am I just as well off to spend the $180 and have it bored to a ls1 since I have the pistons, rods, and a crank? If I go ahead and bore what cam do I need to be looking for? I am trying to get the rest of my parts together is why I am asking all the questions. This motor will need to be able to smoke 2 295/40/20's. I installed a eaton posi and some 3:73's
Thanks for all the help
Old 08-13-2007, 02:50 PM
  #53
Took it to the machine shop today to get it bored to a 5.7, decided to go that route but I am still gonna tell people it is a 4.8
Old 08-13-2007, 02:55 PM
  #54
ChevyThunder17's Avatar
Do you know what they are boring it out to? 3.898, 3.905?
Old 08-13-2007, 07:08 PM
  #55
I told him to bore it to 3.898.
Old 08-13-2007, 08:39 PM
  #56
11 Second Club
Z28RPM's Avatar
Try this sight it will tell u everything u need to know about Gen III engines u need to know for your build.
http://www.automotiverebuilder.com/ar/eb040538.htm
Old 08-13-2007, 08:44 PM
  #57
kbracing96's Avatar
Thank You for posting that, I used to have it but my old laptop died with it on it and I haden't found it again. VERY good info there
Old 08-13-2007, 09:46 PM
  #58
That site says to not bore the 6.0 iron over .010" either, which doesn't make sense in that lots of people bore them out anywhere between .030 to .060 over.
Old 08-13-2007, 11:03 PM
  #59
11 Second Club
Z28RPM's Avatar
yea the LS3 is actulay a 6.0 Punched out .060 over. It ses right on the factory piston .060
Old 08-14-2007, 11:21 AM
  #60
TXARKITEKT's Avatar
What is the advantage to running it backwards? Wouldn't getting the intake plumbing to it be a problem?
Quick Reply: 4.8 turned into a 5.3???? I need help!!!!
