4.8 vs 5.3
Old 05-10-2006, 02:20 PM
  #21
black4.8's Avatar
both great motors both great potential, but i agree w/ the 1/1 cu in/hp in the 4.8
Old 05-10-2006, 06:32 PM
  #22
ONLYA4.8L's Avatar
Werd.. I have a 4.8l but wish I had a 5.3l sometimes...lol I think they made the 4.8l is to take out Fords 4.6.. and Dodges. 4.7L.. Yeah What now?!!hahaha
Old 05-10-2006, 09:47 PM
  #23
blt2lay's Avatar
so, it is unrealistic money wise to upgrade your 4.8 to a 5.3.
also can you bore out the 4.8 to fit the 5.7 piston rod cramk set up?
would that be a better option for money. oviouly this route will be more but greater overall effect
Old 05-11-2006, 02:52 PM
  #24
TurboGibbs's Avatar
yes, the ls1 bore size is the max you want to go though. possibly the more economical thing would be to get a crank and rods out of a 5.3. They have the same rods and stroke as a 5.7 ls1. Just buy some good ls1 pistons.
Old 05-11-2006, 04:16 PM
  #25
blt2lay's Avatar
cool thanks for the info gonna look on ebay for 5.3 crank and roods then get some aftermarket pistons
Old 05-11-2006, 08:57 PM
  #26
ONLYA4.8L's Avatar
Yeah.. I hear JE make good LS1 pistons..
Old 05-11-2006, 10:03 PM
  #27
JE? i'd be interested in some ls1 pistons, what kinda improvement woudl you expect to see in those aside from the difficulty of install but it woudl be a cool thing to do during a cam swap...what kinda suporting mods wouldbe needed?
Old 05-12-2006, 08:37 AM
  #28
TurboGibbs's Avatar
the entire engine would have to come out and the block bored of course. No other supporting mods needed. The 4.8/5.3 heads have a little smaller combustion chamber so that would need to be considered when looking at compression ratings on pistons for an LS1. I'd put a set of $69 arp rod bolts in it while it was out. Also you need to look for pistons for a 6.098 rod length and a .945 wrist pin. The 6.125 .927 is an aftermarket rod. JE, Mahle, & Diamond all have a good selection of off-the-shelf gen 3 pistons.
Old 05-13-2006, 12:46 AM
  #29
sounds like something to do when im getting in this real big with big money, sounds in the price range of a turbo with all the boring and engine removal... a little more than i expected, maybe later
Old 05-15-2006, 10:45 AM
  #30
therat1989's Avatar
If we could get some time slips between all the motors we could do a better comparo. 4.8 vs 5.3 vs 6.0.
Whats the differences between the reg. 6.0 and the Vortec MAX?
Quick Reply: 4.8 vs 5.3
