408 Cid Hp
Old 02-25-2007 | 12:21 PM
Z-71's Avatar
Lightbulb 408 Cid Hp
Hi guys
I have a question ,, how many HP & TQ on the 408 cid stroker? ( without NOS wet or dry)
Which the best for the trucks Short Block or long Block?
Old 02-25-2007 | 12:45 PM
ZR1 DREAMING's Avatar
That's a pretty vague question. Try stating specifics like what you're looking for and what your plans are. And you say shortblock.... well what kind of top end are you planning? Stock? Any cam specs? Stock?
With a further detailed question we can help more accurately.
But FWIW, I've seen some nice stroker shortblocks from TSP and SDPC (both sponsors).
Old 02-25-2007 | 12:53 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by Z-71
Hi guys
Me thinks you are a bit confused?
HP/TQ output of an engine is dependant on too many factors like compression, heads, intake, exhaust, etc.
A shortblock is a long block minus some parts so both are good for trucks, just depends if you want to buy the parts assembled or seperate.
By the way, NOS is a brand name, N2O (nitrous oxide) is the product.
Old 02-25-2007 | 01:33 PM
Stoichiometric's Avatar
I think a 408 at 11:1 compression with a moderate cam (~230 duration .600 lift) and ported heads with big valves should do 450/450 at the wheels with the all the supporting mods.
Old 02-25-2007 | 02:18 PM
Z-71's Avatar
Z06 DREAMING ,,, 408cid LS1 / LQ9 Iron Stroker Long Block
PRC stage 3 cylinder heads + Comp 850-16 roller lifters + TSP hardened pushrods, GM head bolts and gaskets.
ARP 12-Pt Head Stud kit + Diamond -15cc Pistons + Eagle LS1 Forged Crankshaft + Callies 6.125'' Compstar Rods.
http://texas-speed.com/shop/item.asp
Thank you very much
trever1t ,,, Thank you very much, you are right about N2O
Stoichiometric ,,, Thank you very much for the information
Old 02-25-2007 | 03:43 PM
Thank you very much
why -15cc pistons? Is there a chance for FI later? What are the specs on that cam?
All in all that's a healthy combo... would perform great in a truck!
Depending on the cam and induction I'd estimate 450-500fwhp. Swap pistons for higher CR and a large cam with a 90/90 or spyder style intake and you'll easily see 520+ fwhp.
Old 02-25-2007 | 04:12 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
If you're going NA boost the compression. Those -15cc dish pistons will take you to around 9:1 I think unless you mill the heads.
Either look for an NA package or call speed and tell'em you want NA pistons and 10.5 or 11:1 compression.
Old 02-26-2007 | 01:28 AM
Z-71's Avatar
Z06 DREAMING ,,, i'm planning to add M122 magnacharger or Single turbo, but i'm a bit confused which the best cam will work good with those kits. They recommended Low compression if i want to add FI. Thank you very much for your support
TurboBerserker ,,, i'll call texas-speed again and i'll check about NA package.
Old 02-26-2007 | 08:51 AM
blown3qtr's Avatar
Thank you very much
That's pretty close to my set up. It puts me at about 10:1-10.1:1. my heads cc'd out at 69cc. Can tell you more once I get her runnin'.
Old 02-26-2007 | 09:28 AM
I AM A MOTHERF*CKER
If you are going FI *don't* get the NA package. Each option (MP122 or turbo) would want a different cam, so pick that first. The compression target may change too.
Let's do it this way... How much power do you want to make?
