408 Cid Hp
blown3qtr ,, thats good set up,, about the cylinder heads i'm going to use Stage 3 CNC ported cylinder heads 72cc Chamber.
Thank you for your support
TurboBerserker ,,, i want to make around 650-750rwhp ,, but for know i don't know how much power the 408 will make before adding FI?
Thank you very much
Thank you very much
Running a 408 that is set up for NA will make much more baseline power than a 408 that is set up for high boost -- 11:1 compression for NA and 8.7:1 for high boost.
To make 750 rwhp, I'd run a 9:1 forged 408 with a turbo, FMIC and meth capable of 15 psi.
Thank you very much
Thank you very much
blown3qtr ,,, with 9.5:1 compression ratio you can go with up to 15-20psi , i have seen some people in my counrty using Toyota Land Crusier 4.5L 24valve I-6 engine stroker and Nissan Patrol with 4.8L V6 stroker kit with Y2K Turbo + 800 MOTEC and they runs easy 15-20psi and some people runs 2,4 bar of boost making 650-750rwhp. The compression close to yours or higher in a smaller engines.
yurs78 ,,,, i'm not sure which injection they are using. You are right its too much boost in small engines. also its not for a daily driver, but i gave this example because the 408 stroker with 9.5:1 compression ratio can reach this power without problem.
It is not too high boost at all for 408ci. First you have to think about size of turbo. because you'll get more boost on cold days, good 2-4psi cold day, less psi on Hot day.
if you looking to achieve 750WHP, most likely you'll need gt76.
You can go high as around 20psi if you have crisp tune.
