408 compression ratio
#21
I AM A MOTHERF*CKER
Originally Posted by Stoichiometric
EXTREME, I am building my own. There are only so many ways to plumb a front mount single, so you already know about how it will look.
TB, 700s to the ground would be cool
! The cam you mentioned is exactly what I originally wanted to put in my 408, after talking to a couple people I though that I could afford to scale it down a little. How does your truck respond on the street with your cam and that boost level? Your set-up sounds very close to what I want to build.
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
As I said, I run 8.6:1 with MLS gaskets -- they are great turbo gaskets imo. I believe parish is about the same CR and his cam is very close to what I run. Not sure what he does for gaskets (I think cometics, but not sure).
AS others have said, no real need to sweat 20psi unless you just want it (like me
![Icondrool](https://www.performancetrucks.net/forums/images/smilies2/icondrool.gif)
![Burnout](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_burnout.gif)
#22
If I can handle 20psi safely, there is no reason why I wouldn't want it
. I plan to work my way up to a level that is still reasonable on the street, but I already know that I will be turning it up down the road.
Right now my suspension is bone stock (2500HD), but soon I will remove the overload spring and add some Cal-tracs in the rear. My 14bolt should handle more power than my tires, maybe not the G80 though. Do you think the stock 80e will last a little while with a shift kit?
I have been debating twin turbo vs. single at the moment. I was last thinking about twin GT35Rs with tubular exhaust and merge collectors
. Its funny how everything snowballs. If anyone has an opinion on the twin vs. single, I appreciate the input. Thank you guys for the help so far.
![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
![EEK !!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_eek2.gif)
#23
Tin Foil Hat Wearin' Fool
Originally Posted by TurboBerserker
Er... Been running MLS for 2 years on a 4.03 bore
They work great, don't lift, etc. I do have head studs and have 'em overtorqued 15 ft/lbs however.
#24
what a rush!
![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
#25
8:1CR will SUCK while out of boost. Especially in your heavy truck. If you arent shooting for 20+psi then I would shoot for 9:1 Ill be running 9.3:1 to help out with off boost driving.
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
#26
Originally Posted by moregrip
my G80 was fine on the street, but didn't last one trip down the strip ![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
#29
I AM A MOTHERF*CKER
G80s are weird. It might last forever, might blow up the first time you hit it. I've got a detroit locker going in mine. The 14 bolt you have (9.5" sf) will work fine (with a locker or lsd upgrade) for as much HP as you can get in a street driven truck imo.
Why you wouldn't want 20psi comes down to how much time you will spend at 20psi. High boost means a sacrifice of something when not in high boost -- gas mileage, street manners, etc. If you are like me, none of that matters, but I thought I'd mention it
#30
That is some good advise. I have a lot to consider right now. Gas milage is not important to me, driveability means a little. I can put up with some stuff but I don't want to drive a race vehicle around on the street. I want to run large(er) turbos that can take advantage of my heads/intake, but I also want to make them as responsive as possible(of course I want to have everything
) by using the merge collectors . I care most about transient response when the truck is already rolling. I have 4.10 gears and was going to try to run the stock converter. I am not opposed to changing things down the road to optimize the set-up, I want to get going with the least modifications so I can choose them later on.
