408 Hp
Can you be a little more specific on your motor specs??? Cam duration, heads (ported), intake, headers etc.
My N/A 408 was able to hit 613HP on the engine dyno with a base tune. I expect after some wear-in and tuning, 625-650 isn't out of the question. I really wanted to see where the power was made rather than peak numbers and to break in the motor in a WOT situation. I am happy with the results.
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
My N/A 408 was able to hit 613HP on the engine dyno with a base tune. I expect after some wear-in and tuning, 625-650 isn't out of the question. I really wanted to see where the power was made rather than peak numbers and to break in the motor in a WOT situation. I am happy with the results.![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
I think that will be a great cam for a daily driver 408. I've driven them with smaller cams than that. With that cam you should be able to make 450RWHP and have it drive nice. Just because it's a 408 doesn't mean it needs a big cam. Bigger flowing heads are more important than a bigger cam with the big cubes.
Thats what i though but couldnt remember for sure it was like 2 yrs ago the shop that did them couldnt find any # from when they did them. I thought that we went to the 5.3s 61.1 cc they took off .045. It will be a DD untill I can find a RCSB to put it in.
