The 420 is DONE!!!!!!!!!!
#191
I feel for ya Cody. I'm having hell staying motivated working on my dads truck too (the 72). I'm in the finish welding, grinding, cleanup, rattle caning of the front end and suspension before I can put everything together and put in the 5.3 motor, and just don't want to do it. Then I got to figure out all the wiring for the motor and trans.
#192
Well, I would have enjoyed listening to you squall under the truck getting burned while I was drinking a cold one and watching like old times.
I tell you what, you pre-plan like my wife makes money. You need to seriously get a hold of 1slowhoe and get some of that Gay Texan Remover he has. You are just all ate up with that curse.
#197
Originally Posted by 1SlowHoe
LMAO! I know I've had days just like that under the Tahoe.
You really need to pull the header to clean it? Cant you just let that crap burn off on the first start-up?
#198
Some days are not fun at all. I just threw a sweatshirt away that was 100% soaked in ATF from my adventures with a burr on a front oil pump and bench pressing a full converter under the truck, all day. It's worth it when the truck runs good, hopefully you shouldn't be much farther away.
#200
Holy **** Cody! I feel bad for you. I thought I had bad luck.
I hope my trans swap works out better than everything on your truck has. I plan on getting it in real soon! Working on setting up a date with my buddy that has the lift. Looking forward to finally getting it in.
