The 420 is DONE!!!!!!!!!!
Old 09-04-2007, 08:54 PM
  #301
what a rush!
moregrip's Avatar
Are the symptoms Im describing indicative of no vacuum being pulled on the brake booster?
I would say yes
Old 09-04-2007, 08:58 PM
  #302
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Hmm, how can I check it without the motor dying on me with the massive vacuum leak its going to have when I pull the brake booster hose off? I guess I should start by pulling the hose off the back of the intake and putting my finger over it and see if its pulling vacuum, then if it is throw the hose of a buddys truck on mine and see if that cures it. Before this is all said and done I might just have to convert to hydraboost sooner then I was planning
Old 09-04-2007, 09:52 PM
  #303
FormerVendor
Richard@WCCH's Avatar
Wow! That truck sounds great Cody. A couple of miles of driving and the smoke should burn out of the pipes and exhaust system.
I like your guages. Very cool on the eyes.
If your pedal goes to the floor when the engine is off, you have no hydraulic pressure in the brake system. More than likely you have an air bubble in the system but a bad master cylinder could also be the culprit. I'd be suprised if your booster quit working from sitting, but I supppose anything is possible.
If your pedal goes halfway down before it gets firm, then you've lost either front or rear brakes but not both. You mentioned a leaky banjo fitting and that's probably where the air entered the system. Try bleeding that caliper first and see if you don't get a better pedal. I would suggest trying to firm up the brake pedal before you change out the pads and fluid just to be sure you nail the problem.
Thanks for the Rex clip.
Richard
Old 09-04-2007, 10:03 PM
  #304
1slow01Z71's Avatar
Thanks Richard, alot of the smoke is actually condensate if you noticed the ground is wet, its humid as hell since its been raining all day. You can kinda see when the "smoke" goes from a blue tint back to a greyish color thats the condensate. Im going to see if I can talk James in to coming over tomorrow night and helping me bleed the brakes. The master cylinder was LOW, it took about 12oz to get it close to the max line.
Old 09-04-2007, 10:09 PM
  #305
FormerVendor
Yeah, it appears that it's just some air in the bake lines or caliper. Pretty much a two man job unless you have a power bleeder. I bet you get the air bubbles out in the first couple of pumps and then you'll have some brakes.
Good luck.
Richard
Old 09-04-2007, 10:12 PM
  #306
1slow01Z71's Avatar
Maybe you could call James in the morning and sweet talk him into coming over tomorrow night
Thanks for all the help buddy, I cant wait to drive this thing and get the other video Rex requested
Old 09-04-2007, 10:20 PM
  #307
Destroyer of Transmissions
1SlowHoe's Avatar
Brakes
Is that your latest excuse?
Old 09-07-2007, 03:07 PM
  #308
TurboGibbs's Avatar
Originally Posted by TurboGibbs
Well, about damn time. Now it's just going to take another 2 months to get it running.
I was searching the thread to try to find the specs on the cam when I ran across this post on 7/5/07.
I was close.
So whats em erh cam numbers gin?
Old 09-07-2007, 03:18 PM
  #309
1slow01Z71's Avatar
224/224 .565 .565 on a 112 or 114 I never cam remember, I think its 112.
Old 09-07-2007, 03:25 PM
  #310
02Denali6L's Avatar
Originally Posted by 1SlowHoe
Brakes
Cody, its the big pedal on the left...
Just get it running and head to Pensacola. The track at Holt will help you break it in.
Quick Reply: The 420 is DONE!!!!!!!!!!
