5.3 Cam question??
Old 05-05-2009, 12:53 PM
Basool's Avatar
Question 5.3 Cam question??
Hey guys, i got a new cam for my 5.3 avalanche..specs Lift .630/.644 Duration 215/231 Lobe 118..i also got Patriot Gold .650" kit By the way do i need to change the pushrods for hardened ones or is it okay to leave it as it is?
Old 05-05-2009, 01:26 PM
10 Second Club
Z28FirefighterI1's Avatar
The stock rod are weak, you'll need new hardened one for sure. The biggest cam i'd run on stockers is a LS6, there just not made for the heavy spring and high RPM's.
Old 05-06-2009, 07:12 AM
Basool's Avatar
how long will it last without hardened pushrods?
Old 05-06-2009, 08:32 AM
sonoma43's Avatar
not very long...they will bend for sure
Old 05-06-2009, 10:40 AM
Slimsilverado's Avatar
Thats a super big cam for a heavy avalanche..........
Old 05-06-2009, 11:30 AM
Basool's Avatar
loooool yea but atleast ill make it fly a bit..how do u think it will turn out?
Old 05-06-2009, 11:36 AM
pewterliftedz's Avatar
ur gonna need a big ol' stall for that cam...
what size are u plannin???
Old 05-06-2009, 12:25 PM
Basool's Avatar
im thinkin of a Yank 3200??
Old 05-06-2009, 12:29 PM
Baltimore Whore
Mangled03gmc's Avatar
Too much cam(lift), for stock heads... You will also want hardened push rods, regardless of what cam you change to
Old 05-06-2009, 12:36 PM
disstrucktive's Avatar
for sure u going 2 need aftermarket pushrods, your gonna have a massive lift, imo u would beniffit more from a larger stall more like 3600-4000 range...i got a pi 3600 and thinking of gettinga a bigger one....good luck
Quick Reply: 5.3 Cam question??
