5.3 with flat top pistons & 706 heads with valve job
Ok thanks all. Yes i would like to get CNC Ported heads Through SDPC but since i am having a shop do the build would it be bad taste to tell them that i will get the heads? rather than having them get heads and sending to a machine shop and then they would complete them. I don't want to step on any toes. He did say he could get 243 heads for around $600 but these would still need work.
Its pretty easy, the only special tools you need are a torque wrench and angle meter to seat and install the rod and main bearings.
The connecting rods are press fit to the pistons so you need to take them to a machine shop to have the new pistons swapped over to the rods. Also the machine shop can polish your stock 5.3 crank or grind it if it's in bad shape, they should also have the correct size bearing in stock as well.
Angle Meter
Amazon.com: Lisle 28100 Torque Angle Meter: Automotive
Angle Meter
Custm2500's Rude Friend
Angle Meter
Angle Meter
The LQ9 got them in late 03 as the second design.
Angle Meter
Angle Meter
Neat tool, but you only need that if you are using torque to yield bolts (stock replacement) not needed if yuing ARP stuff
