5.3 head work and cam
#21
So more less wut yaw are sayin is run the pac 1218's rather than the ls6 springs? Not to many ppl around here where i live do this kinda stuff so thats why im having to ask yaw wuts best to use.
#22
PT's Slowest Truck
Depends on which cam you choose...if going with the Comp 212/218, low or high lift, the LS6 springs will be fine, but for the TR220 that was recommended, I'd run the 1218's if it were me. You'd probably be fine with LS6 springs, but should definitely be fine with 1218's, which are comparable (read: same thing minus the Comp breakage problems) to the Comp 918's that Thunder Racing recommends with that cam.
#23
The PAC 1218's and Comp 918's actually have the same exact specs, except that the Comp's are known to break and the PAC's seem to have a great track record so far. It's my understanding that PAC used to make the springs for Comp, but Comp changed suppliers...probably getting a better deal on the junk their selling now.
07NBSChevy
20
07-08-2015 07:27 PM
