5.3 into 5.7
the only difference between the 5.7 and 5.3 is the bore size. therefore use your 5.3 crank and rods and get 5.7 pistons for the larger bore and your good to go....yes you can bore to 3.905, remember this is an iron block so it is not as critical as boring an aluminum block.....
No, the bore is the same, the crank is shorter stroke and rods are longer and pistons are flat toped. Yes you can bore a 4.8 block to 3.905
No sense in making another thread if this is here then. I asked this similar question over on your sister site LS1tech, they referred me to here.
https://ls1tech.com/forums/showthrea...26#post8708526
Now that the 5.3L to 5.7L question has been answered, which pistons would you guys use to get a relatively high compression ratio requiring mid octane gasoline and a cam meant for idle-5000rpms?
Thanks,
InchUp
Thanks,
InchUp
You can get forged pistons as cheap as stocker LS1 pistons. I think we got my son's from Texas Speed. With a Zo6 cam and LS1 or LQ4 heads, you're ready to be blown, sprayed, or leave it alone and enjoy about 400 hp at the crank. I wouldn't even think of building a 5.7L with cast pistons. You have it apart.....put it back together right.
Thanks for the reply. I've been looking on their site for awhile now and I'm liking what I see.
Is there a certain piston you'd recommend using the 99mm bore, stock rods, stock crank and stock 5.3L heads to yield somewhere in the 9.8-10.2:1 compression range? I've been considering this camshaft for awhile now for my engine, the XR259 cam from CompCAMS.
http://store.summitracing.com/partde...1&autoview=sku
All I'm looking for in this motor is decent power, somewhere in the neighborhood of 1hp/cubic inch, and similar torque numbers while still getting respectable gas mileage. This is not intended to be a racing motor of any kind, all low end grunt.
What would I have to change on the 5.3L heads to make them work with the larger bore? I'd love a 6.0L, and actually planned on putting one in instead of a 5.3/5.7, but I don't have a 6.0L, I have a 5.3L truck motor that needs a rebuild.
I'm trying to make do with what I have.
