5.3 into 5.7
Old 02-17-2008 | 10:53 AM
  #21
silver-mod-o's Avatar
Hunt&Fisherator
There's no problem running the 5.3L heads on a 5.7 bore size. TONS of LS1s have some mildly ported 5.3 heads (with bigger valves) and put down very solid numbers with them. When I go to a 5.7 (this year) I'll either go to some 243's or have my 706 truck heads worked over. Lost of aftermarket porters use the 5.3 castings with great results.
Old 02-17-2008 | 04:37 PM
  #22
LSCamino's Avatar
The engines are internally balanced therefore the 5.3 crank and the 5.7 crank each have different part numbers though they have the same stroke. The 5.3 heads on a 5.7 will raise the compression which in turn would raise the power, but, also, raised the possibility of detonation. I would recommend reading, "How to Build High-Performance Chevy LS1/LS6 V-8s". It covers the Gen III 4.8 through the 6.0 Vortec truck engines. In "Car Craft" magazine, April 08 issue, (I think), there is a very good article on a junk yard 5.3 with just a cam change, running a carb putting out over 400 hp.
Old 02-18-2008 | 08:42 PM
  #23
Dark Halo's Avatar
you can add me to the 5.7 iron block list I just need to find a good priced piston.
Old 02-26-2008 | 03:22 PM
  #24
Hunt&Fisherator
Thats not that big of a feat to be honest... I'm sure thats rated at the crank, not the wheels... 400 RWHP out of a 5.3 with no power adder is the white elephant though...
Old 02-26-2008 | 04:37 PM
  #25
InchUp's Avatar
No kidding. Haha. That's like 460hp at the flywheel. It's a task for LS6's to do that, let alone a 5.3L.
Old 02-26-2008 | 04:58 PM
  #26
nighthawk08's Avatar
go look in the dyno section at LA TOMBSTONE's post to see a white elephant
Old 02-26-2008 | 05:23 PM
  #27
Hunt&Fisherator
and?? numbers... just numbers...
I had a dyno tell me that I was making over 340/380 BEFORE I did a cam and a good tune... you can make any dyno spit out any number you want. Its a tuning tool...not a dick measuring-tape...
Props to him for the numbers.... I suppose... but 400 with the mods they have listed there isnt going to happen... "Junkyard 5.3 with a cam change and carb" isnt going to cut it, not for 400 REAL Hp
Old 02-26-2008 | 05:37 PM
  #28
xlcooplx's Avatar
TAPyvehc93
12-27-2015 01:14 PM
pewter00
09-14-2015 10:17 PM
sTNT971
09-11-2015 03:38 AM
11MPG
09-10-2015 09:34 PM
11MPG
09-08-2015 05:52 AM
