5.3 power question
5.3 power question
i have a 5.3 laying around with low miles. im thinking of getting some of my spare ls1 heads milled to make the compression of the 5.3s that way i will have ls1 flow with 5.3 compression. its going in a 97 cobra probably carbed wondering what kind of power it should make with say a 224/227 cam or if i can go bigger on the cam. mainly worried about the power. if i can get mid 400s n hit it with a 100 shot id be happy. would cost way less than buying a ls1 bottom end
ive seen a ls1 with carb conversion and 220cam put down 410 on engine dyno thats a huge gain over stock just from that little cam and a carb. i was hopeing for closer to 400 atleast and be able to spray 100 if wanted
the 5.3 heads are the same as ls1 with smaller chamber. same flow numbers. that duration cam with lift numbers round .600 with appropriate valvetrain should get your horsepower number with a victor jr intake since your thinkin carbed. this is considering you gonna have full length custom headers and dual exhaust. sounds like a good upgrade for the cobra, lol. have fun with it
i know all about the flow differences of the 5.3 vs ls and thats why i was goin to get the ls1 heads milled to make the compression of the 5.3s it should be alot cheaper than getting the 5.3's worked to accept the ls valves and p/p. someone tell me if im wrong. does anyone have any idea about the power numbers it should make? ant it will most likely have a 4l60e with manual valve body, and the 8.8 mustang rear end since they can take alot of abuse.
Youre comparing 5.3 and ls1 head flow numbers based on a 3.9 bore. throw those ls1 heads on a 5.3 bore of 3.779 and Im willing to bet the 5.3 heads pull out on top in terms of flow numbers. Gm could have just shrunk the combustion chamber on the ls head to make the 5.3s, but opted for the smaller valves to remove any shrouding issues.
Just get a good valve job done and mill the 5.3 heads to bump the compression up. Youll end up with more and better flow on a 5.3.
I am also going to use the 5.3 for my 93 Mustang notch, I found this article from Car Craft. Very interesting build. If you guys have read this already please dont flame me ho hard. I am still a noobie!
http://www.carcraft.com/techarticles...ine/index.html
I just wonder how much power the stock internals can make. I know tune and RPM have factors in the answer, but have not been able find out much info.
grantpo
07-15-2015 12:21 PM
