5.3 questions
#21
Whats the price on the Eldebrock heads? I'll probably do what I did before and call COMP cams and talk to the tech after I decide on a set of heads, gears and stall speed. Thanks for the input so far fellas.
#22
FormerVendor
We sell them with beehive springs for $1990.00 per set. Dual springs and titanium retainers will add $125.00. I've got a set in stock. Give us a call if you have more questions.
Richard
Richard
#24
FormerVendor
Here's a link to some online info about these heads. Click here.
Sorry no pics available yet, but we're working on that.
Richard
Richard
#25
so 59cc heads will bump us up to 10to1cr correct and what about pushrod lenght? do we need to go shorter. and 10.5to1 compression would be great with just a .030mill
#26
Mr. Obvious
i dont know if the 317 heads FLOW better but they will KILL your compression ratio i would suggest getting richard's 5.3L heads and be done with the heads and there are tons of cams out there to chose from so look at a lot before you make your decision
i always thought reverse split cams were usually used on turbo'd motors
#27
FormerVendor
Richard
