5.3 rod bolts?
5.3 rod bolts?
I know the ls1 guys run katech rod bolts and spin them 7200 and up. Is it worth replacing the rod bolts in the 5.3's? I wouldnt mind spinning to 6800 or so.
Baltimore Whore
If the engine has been running fine, leave it. Doing bolts can change the stress on the caps, can cause what was a good bearing to go bad, from changing bolts, re torquing. Other things tend to leave before a bolt breaks. If it is a afresh build, then yes to have some piece of mind put the good bolts in other wise, drive on..
Like John said, I would leave the bolts if you do not have any problems. When you change bolts you need to check the rods for roundness, if you are not checking, this can cause bearing failure as there is a different clamping stress on the rod. In my first build I spent the money for Katech rod bolts because I didn't have to balance or check. I now feel like that was a waste of money as I have never heard of a rod bolt failure .
