5.3 TR 224 cam H/C/I
Hey guys with a TR224 cam a FAST 90mm and a set of heads( i can't figure out which heads to go with but i was thinking stage 2 patriot heads) what kinda of dyno numbers can i excepect. (thisincludes LT's and 2.5 inch exhuast with efans) out of a 5.3
Fastest D1 Procharged Truck
there was a built up of a stout 5.3 over on RGV performace trucks it made 490 to the flywheel ill see if i can find it
found this on LS1tech:
Here's what was in the engine:
5.3 block aluminum (doesn't really matter if it's iron)
4.8 flat top pistons
5.3 rods - ARP rod bolts
5.3 crank
LS2 timing chain on 5.3 sprockets
LS2 intake/injectors/fuel rail (modified by Turn Key)
90mm Turn Key throttle body
220/224 112 LSA Trick Flow cam (.575 lift)
Trick Flow 205 CNC ported heads (assembled)
Harland Sharp pedestal mount 1.7 rockers
Trick Flow 7.500 chromemoly pushrods
Correction factor was 1.046
91 octane pump gas on a Superflow 901 engine dyno. We estimate compression at around 11.5:1
5.3 crank
