5.3 upgrades
I agree, that cam in a 5.3 wouldn't fall into my personal category of "streetable" as in a daily driver. It will have a high powerband and require a high stall converter or it will be soggy down low. I'd also recommend headwork such as porting and milling. The TR220 is a proven 5.3 performer that will work well with the compression and heads in stock form, and will work nicely with a more street friendly 3k-3200 converter. There are a lot of guys around here who daily drive 3600+ converters, but it can be a pain in the butt on a daily basis, especially when you're groggy and sitting in traffic on your way to work in the AM.
It's in between there somewhere. Stall speed changes with your powerband, so be aware of that when choosing a cam/converter combo. With my old 216/220, I might have had a little more torque in the low low RPM band, and it used to feel like it was looser. When I swapped to the 228, the immediate flashing of the torque converter felt like it tightened up some, but the RPM extensions stayed the same from what I can tell.
Yea, I'm expecting to see a decent change from when I use my Circle-D triple disc behind my current set up, then go to an LQ9. Chris said it should be about 2600-2800 behind my 5.3, and probably around 2800-3000 behind the 6.0...can't wait
