5.3l and 4.8 block question?
is the 5.3 block and the 4.8L. block is the same block can i put in a 5.3 crank in the 4.8 block and bore it out to a 347 with 3.905 bore with forged pistons for FI and will work fine with no problems. And is the wheel in the back of the crank with the same part number is the same as all the cranks with the same part numbers it will have the same teeth on them.
but can i bore out he 4.8 block to a 5.7 with 3.905 Mahle pistons is it possible and with no problems with the block still having enough metal in the bores for FI engine turbocharged.
