5.7L Vortec Mods
Old 11-03-2006, 08:08 PM
  #21
Originally Posted by MCDiver
I have looked into new manifolds for the vortec engines on the 97-98 (99 on Tahoes) and have come up with nothing. The Thorley Tri-y's are the only non-short tube headers I can find. This has not been a fun process. Most of what I am doing will be internal mods. The sad thing is that with all of these motores on the street, the aftermarket will not make parts for us.
Mike
Hooker makes long-tubes for our trucks. Check out pacificp, a few guys have em. The only options are carbed intakes (either using a carb or converting to efi and lots of wiring) or marine manifold (everything pretty much bolts up but lots of wiring still and fuel lines)
Old 11-03-2006, 09:53 PM
  #22
hog
hog's Avatar
Marine Intake
http://www.pacificp.com/forum/viewtopic.php?t=317
Hooker Longtube headers
These are the 2805 HKR $400 painted, $750 ceramic coated equa; l;ength 1 3/4" primary 3"c ollector Hooker Super Competition longtubes.
http://www.pacificp.com/forum/viewtopic.php?t=2415
http://www.pacificp.com/forum/viewto...oker+longtubes
I am running the $180 painted $350 ceramic coated and $540 stainles steel
1 5/8" primary non-equal length 2 1/2" collectors pn 2462 HKR.
With a mild Fastchips PCM tune and teh headers I dropped 3/4's of a second in the 1/4 mile.
ghere is some furthur info on installing ANY header into a 1996-2002 Vortec 350/305 vehicle.
http://www.pacificp.com/forum/viewto...+fitting#14630
here is the Pacific Performace Engineeriong Performance Truck site
http://www.pacificp.com/forum/index.php
peace
Hog
Old 11-03-2006, 11:02 PM
  #23
you da man
Old 11-04-2006, 12:12 AM
  #24
Made in South Korea
Snacktime's Avatar
I stoped at headers and intake with my 96, I would go after the marine intake(came about after I sold the truck).
Old 11-09-2006, 05:26 PM
  #25
Vortec350ss's Avatar
What about the RamJet manifold? I would assume that its a similar process to get that working instead of the marine manifold. I would also think that its worth a few ponies over the marine as well. The only difference would be setting up an intake to work with the manifold, because obv. the throttle body is in a different location.
Hog, what do you think of the RamJet in comparison to the Marine? I am planning the RamJet swap for this may.
-Rob Nap
Old 11-10-2006, 07:11 PM
  #26
hog
hog's Avatar
The Ramjet is probably worth a few hp as it is more of a tunnel ram intake while the Marine intake is a cross Ram setup.
The Ramjet forces sthe intake air to tun 90° the Marine intajke doesnt due to its TB position.
I would love to see a dyno sheet comparing the 2.
The Ramjet install would be a tad more involved, but could be done nonethe less.
peace
Hog
Old 11-12-2006, 06:20 PM
  #27
Hopefully I will be able to let you know about it. I am seriosuly planning it for the spring, but I would like to be doing a cam swap too, so it wont be a complete comparison. Maybe if we could compare them with the same cam... Hog you wanna do a cam swap???
-Rob Nap
Old 12-02-2006, 01:13 AM
  #28
craze4speed's Avatar
my buddy had a 98 silverado with the vortech 350 and it had hooker long tube headers k&n cold air intake crane cam 210/224 @.50 powermax truck cam, crane powermax tuner, 3:73 gears, shift kit, and a throttle body spacer and he ran consistent 8.60's in 1/8mile hope that helps some!
madmann26
04-29-2020 09:17 AM
02AWDAWSDenali
10-01-2015 05:08 PM
bisqikss
09-27-2015 09:40 PM
GM1697
09-09-2015 10:31 PM
GM1697
09-09-2015 01:52 PM
Quick Reply: 5.7L Vortec Mods
