50PSI oil pressure up to 6000+ RPMs?
Old 10-02-2011, 07:12 PM
MikeGyver's Avatar
Originally Posted by Coban
... The relief valve in the oil pan near the oil filter ...
When did GM start doing that?
Old 10-02-2011, 08:26 PM
1989k1500's Avatar
Originally Posted by ayousef
this is the sort of answer I was waiting to hear, because I can feel there is something HOLDING the pressure at 50is PSI, and it was pretty steady at 50PSI. Ill get alot of answers tomorrow when I figure out for starters what did this engine start its life as before it ended up being a 427
Its probably an LS7 crate engine.
Old 10-02-2011, 09:59 PM
ayousef's Avatar
I think so too, Ive been reading about their (SLP) Camaro ZL1 which is almost the same package as my truck, but that makes me wonder if I really do have an oil pan with the pressure relief valve limiting the oil pressure.
Old 11-04-2011, 09:50 AM
Gray Ghost Silverado's Avatar
Yes, you do have one. Guaranteed. There's nothing wrong with 50psi peak whatsoever. All in all, I bet it was built according to GM spec on the bearing tolerances. I built my G8's L76 at some real tight clearances and because it was once a DoD motor here's it's specs.
Idle at 40*: 58psi
Idle at 180*: 49psi
2000 rpm at 40*: 75psi
2000 rpm at 180*: 60psi.
4000 rpm at 85*: 97psi
4000 rpm at 188*: 78psi
6000 rpm at 205*: 65psi
7000 rpm at 220*: 65psi
The relief valve is open regardless at 65 psi on my engine or else when cold it'd be way over 100psi.
Oobray
06-13-2022 03:38 AM
Mossyoakglock
08-28-2015 12:49 PM
superchomper2003
08-26-2015 09:39 AM
Fast86z
08-23-2015 12:35 AM
05GMC4.8
08-07-2015 09:55 PM
Quick Reply: 50PSI oil pressure up to 6000+ RPMs?
