.568" lift cam - LS6 springs or 918s?
Old 09-04-2008, 11:23 PM
I'm using yellow ls6 springs. my cam is also 567. lift. no problems at all
Old 09-05-2008, 06:50 AM
zippy's Avatar
There are some of the Thunder Racing cams that have very agressive ramp rates. The TR224 isn't one of their more agressive cams.
Old 09-05-2008, 07:07 AM
ap2002's Avatar
Originally Posted by InchUp
The question at hand was if the LS6 springs could be matched with the Comp Cams XR265 high lift camshaft. That has a nice duration set of 212/218 but with mild lift characteristics of .558" intake and .563" exhaust. Looks like the LS6 springs will do fine.
I used that exact cam on my old 01 z71, 212/218 .558/.563 114lsa, it was a custom grind due to the LSA, and i also used the LS6 springs with no problems, i was only shifting it at 6200rpm cause my tranny was still stock, that cam ran pretty good on that heavy truck..
Old 09-05-2008, 08:06 AM
OnyxSilveradoSS's Avatar
Originally Posted by zippy
I have had 3 friends/customers that had their 918's create a window in their block.
what is this "windowing"????
Great spring info Zippy.
Old 09-05-2008, 08:32 AM
zippy's Avatar
Hole in the side of the block.
Old 09-05-2008, 08:44 AM
KevinF56's Avatar
Well this is some good info here, fellas. Thanks a lot. Looks like I'll be searching for a set of LS6 springs, which excites me because it saves me at least $100 over the 918s.
Old 09-05-2008, 09:10 AM
oh...you mean when the 918 stop working and the resulting damage. gotchya.
Old 09-05-2008, 10:04 AM
Registered abuser
1BadAction's Avatar
what about the 921 comps?
Old 09-05-2008, 11:12 AM
PT's Slowest Truck
budhayes3's Avatar
They're even stiffer than the 918's
Old 09-05-2008, 12:14 PM
Registered abuser
1BadAction's Avatar
ok captain obvious. LOL.
To clarify my question, are the 921s more or less durable than the 918s?
Quick Reply: .568" lift cam - LS6 springs or 918s?
