.568" lift cam - LS6 springs or 918s?
Old 09-05-2008, 12:33 PM
  #21
zippy's Avatar
They aren't used very often, but should be much more durable. They are a dual spring system which is pretty much like a backup in case the outer spring breaks.
Old 09-05-2008, 12:44 PM
  #22
Registered abuser
1BadAction's Avatar
Cool... the reason I ask, is I have a 8- 921s and Ti retainers for the intake valves, and 8 - new 918s with Ti retainers for the exhaust valves. Trying to decide if I should keep that setup or just spring (no pun intended) for 8 more 921s. Looks like the cam I'll be using will have a fairly big split and between .580 and .600 lift with XFi lobes.
Old 09-05-2008, 01:34 PM
  #23
zippy's Avatar
The intake valve being your heavier valve is the more common to break a valve spring. If you can get the other 8 cheap enough it would be worth it, but I'd say you are covered.
Old 09-05-2008, 05:51 PM
  #24
Yogi Bear's Avatar
Can you use the same Comp cams retainers that go with the 918s on the LS6 springs?
Old 09-05-2008, 06:20 PM
  #25
zippy's Avatar
Yes, you should be able to.
Old 09-05-2008, 06:38 PM
  #26
Yogi Bear's Avatar
Thanks!
Old 09-06-2008, 03:13 PM
  #27
Hussey's Avatar
Jumping in with my own question, same topic.
I also was looking at the 212-218 .522 .529 , but also hear lots of good talk about the .558 .563 . Just didn't know if the yellow springs were good for both set ups ? Seems like the answer is yes. Do the blue LS springs have higher max lift over yellow or vise versa.
Looking to have a wheatley tune with this combo.
Thanks Good thread.
Old 09-07-2008, 09:38 AM
  #28
PT's Slowest Truck
budhayes3's Avatar
Thanks Good thread.
Vise-versa, the yellow springs can handle more lift than the blue ones
Old 09-07-2008, 10:21 AM
  #29
OnyxSilveradoSS's Avatar
OK is the part # different between any of the new Ls3 springs?
L92 =
LS3 =
Zo6 =
Old 09-08-2008, 06:58 AM
  #30
Hussey's Avatar
Thanks,
Quick Reply: .568" lift cam - LS6 springs or 918s?
