6.0 bored out max?
Old 08-07-2007, 10:15 PM
5 year bitches!
Quik's Avatar
so a 410 is the limit? if that is the case i guess ill just find another block if that is the result
Old 08-07-2007, 10:27 PM
FormerVendor
Richard@WCCH's Avatar
If going FI then keep the bore size as small as possible. If going NA then thinner walls aren't trouble. Once past .030" over on the bore size you should have the block sonic tested to be aware of how thin and where the thin spots are.
Richard
Old 08-07-2007, 10:32 PM
5 year bitches!
Quik's Avatar
so if i can find a fresh block so i stay 402? for a TT setup or just bore it .030 and make it a 408
this also depends on if the walls were scored
Old 08-07-2007, 11:33 PM
Stoichiometric's Avatar
You can get new iron blocks for $695 I think. For boost a 402 would do great.
Old 08-08-2007, 01:58 AM
Ferocity02's Avatar
Biggest I've heard of was .060" over. I wouldn't go that far though.
lukn4trbl355
10-21-2015 11:19 PM
GMCtrk
18
10-06-2015 03:48 PM
turbo6c3
10-05-2015 06:11 PM
Wolftrk99
10-02-2015 08:17 AM
02AWDAWSDenali
10-01-2015 05:08 PM
Quick Reply: 6.0 bored out max?
