6.0 cam bearing question
Got the block striped down, going to replace rod and crank bearings, cam bearings show alot of wear. is there a special tool or way to replace the cam bearings?
They are probably normal looking as weird as that sounds. But a set of durabonds and a cam bearing driver will have you fixed up. A good bearing driver is pretty pricey though. My machine shop charged me like and extra 10 bucks to drive the cam bearings in for me on the last block I had cleaned/checked.
bbowerman
07-26-2015 10:57 PM
