6.0 lq4 lookin for a cam.
I've got a stock 6.0 lq4 milled the 317's 40 thousandths to get the compression up. It's got 4:10's and a 4l60 behind it. This is on a daily driver that I need torque under the curve and reasonable amount of fuel economy. Does someone have a cam that they have used that satisfies this for the most part and has a relatively stock idle. I've been looking toward a cam from comp cams and just looking for ideas.
210/216, .556/.561", 114LSA 112 ICL
that cam that mangled03gmc showed you is a good cam thats what i have in my 6.0 non milled 317s just the cam and true dual 3" all the way out with a tune and 22"s it made 380rwhp and 395rwt to the ground sounds pretty good also not routy soundin eather youll like it
How is the idle on the TR 224, fuel mileage etc. Where did it improve over the stock cam.. I'm not comparing dyno charts I want some more low end punch and a bit more top rpm pull.0-5800 is where I want it the most. Not concerned with much over that.
calsdad
06-15-2023 12:07 AM
