6.0L with 862 heads and compression???
#31
At the 11.3:1 compression you should be able to pull it off. Tuning is going to be important, but I doubt a dyno tune is going to be the solution. Dyno tuning is done at wide open commonly. Unless you're towing at wide open only you're going to need some street tuning also.
#37
I'm planning to put a Corsa Touring system on it in the spring. The stock converter works fine in it. I've never been hard on it from a stop. By the time I took out the open diff and put in a Gov-Lock it was winter time.
