6.4l 392 dodge ram coming to houston
Well i decided to build me a motor right. Im going to drop the 6.1L SHORT BLOCK of to RAGE and take my time buying the best parts and doing it right. It will take a while to build it since i dont have much work right now but should be done by this summer. So ill be going back to a 5.7l to atleast make it to the shoot out and have fun spraying the crap out of it and seeing if i can break my record of 11.87@114 on a 100 shot on a 5.7L
my plans now will be to put the 5.7l back on with stock 03-08 heads and leave my 2009 heads alone for the 392 build and put stock 03-08 heads and a 218/218 cam, so i can have it for the shootout.
This most likely the cam im going with in my 5.7L...... 218/218. this is how my truck should run if not better. The truck in the video has 218/218 cam, LT headers, 4.10's, tune, no stall or heads. The only difference will be that I will have is a 3400 stall and 4.56 gears, and U/D pulley. Not bad for a cam only HEMI
http://www.youtube.com/watch?v=hw1lDSLSKgc
Stu built me a very nice 6.4L(392ci) motor out of a 6.1L Hemi with a nice cam. Problem is I haven't put it in anything yet, lol. He used CP pistons Callies crank and Arrow rods.
10.5cr with 6.1L heads. But, depends on the thickness of the gasket. Also, Stu has some big chamber heads that would lower cr for F/I applications. The 5.7L heads would also lower the cr a bit.
JFortner5
08-20-2015 06:13 PM
FlowmasterMufflers
07-09-2015 11:35 AM
