700 hp cam shaft...sound good?
#31
I like...actually LOVE the way my truck drives as a DD. But as we all are guilty of doing, we get antsy and want to play with things that are fine the way they are. Know what I mean.
I'm just ready for something different. I raced a cammed, intake, exhaust, LT's and tuned C6 tonight and kept up with him no problem...had we had more room I'm sure I could of pulled on him. Like I said it runs strong, just want to do something a bit different and see what else I can pull from this set-up, without compromising the drive ability of the truck.
Tonight I tried to do a burnout for a photoshoot with my big brother and some friends with SS's and I couldn't do a burnout to save my life...get sideways at 70mph...sure no prob!
What's hurting me down low is a few things, gears, 4L80E, Vic jr., cam, LT's, and my boost controller. The biggest of them all I would say is my 3.42's. 2 weeks ago with my 4.10's I was able to do a burnout(albeit I had to rock the truck a little with the brakes). Tonight...Nada. The vic jr. hurts but Thunder550 has the same one and he's fine.
And your right there are some mismatched parts but not as many as you'd think, just a few and they happen to be big ones really, and that was my fault for being a newb when I started this build.
Definitely good advice and from my experiences I too agree 100%, it should be posted somewhere were newbs can see it. But I'm way to far into the game to heed that kinda advice! Then again we have a tendancy to learn from our own mistakes and not from others mistakes, hence why I put my hand on the kettle AFTER my mom told me not too!
Blownchevy has a similar saying but like I told him...too late now!
with your combo i would change a few things but thats just my prefernce now for your idea on what works and what you want is different then what i woudl do, so i wont say or try to force my theory,opinion apond you. good luck with getting things sorted out
#32
LOL...it falls within all the criteria I was looking for!
Is that your old cam? If it is I'll try it out just to see what she'll do on my truck! It at least sounds interesting! Is that lift .575 on the intake and .600 exh? or the other way around? I was aiming at a smaller lift on the exhaust...
#33
I AM A MOTHERF*CKER
You could also just retard the cam you own. First - mine is straight up with no advance ground into it, so you could retard your cam 4* and probably do a lot a better. if that's not enough, you could try another 4*.
Yeah, it's a lot of work, and you'd be doing the same work as a cam swap, BUT you don't have to buy a new cam
The not being able to make boost on the line makes me think something else might be up -- or it could just be the advance plus lower cubes. I could make as more boost than the brakes could hold with a GT70 single on there and the same cam -- but in a 408.
BTW, don't you have a GT76 on there? There's no way that will hit full boost by 2500rpm in an sts set up. My GT70 on the 408 was 3200 (or maybe 3500) rpm. If you're just talking when boost starts, fair enough, but I wouldn't worry too much about having a cam that matches when the boost starts -- full boost, sure, but with a 76 on a 370, I'd think full boost would be pretty close to 4k rpm to begin with.
Looking at your dyno graph, it looks like your turbo starts kicking at 3600 rpm and goes full at 4k-ish. It looks like the turbo starts to fall off around 5200rpm. The turbo is definitely not doing anything big for you at 2500ish. Having said that, if your cam added more low end, you'd get to the turbo quicker for sure. I wouldn't do a 2500-5000 cam personally. I might change out the 4k-7k cam in favor of a better cam for say 3500-6000rpm.
All that exhaust housing is going to do for you is change the spool characteristics and help eliminate exhaust pressure (or add to it). What's your current housing? Is this a P-trim GT76 from STS or ??
#34
Yeah, that cam is way to big for a 2100rpm stall. I had no idea you had a converter that tight. I don't think gears are to blame just yet. I've pulled better 60fts than you with higher gears and a 4.8. You do have to build boost to turn them over, but you should be able to do it a lot easier with a 370.
From your graph, another problem looks like you're not making full boost until 4000rpm, but it does ramp up quickly. If you want low end tq that's probably not a good thing. That coupled with the cam's power band is probably why your hp/tq numbers look damn near like a shot of n2o. I think the biggest issue is the cam and the tight stall and the other lack of low end comes from the fact that the turbo is 15ft away.
#38
BTW, don't you have a GT76 on there? ... if your cam added more low end, you'd get to the turbo quicker for sure. I wouldn't do a 2500-5000 cam personally...
That's all I'm trying to do actually. Give the engine a torquier cam, and hopefully it will lower to spool time. Just by the fact it has more torque down low will increase the power under curve which is all I'm looking to do.
#39
#40
Have you checked for exhaust leaks? What boost controller do you have, and how is it controlling the wg. I thought you posted something about a 2100rpm converter. Either way, 2600 is too tight for that cam too. You should be able to build way more that 4psi too. That's bad even for a rear mount. Your cam has 3 deg of overlap, which isn't that bad for boost. Even at low rpm it's not bleeding off too much boost. I think it's because it's lazy down low, and your truck is pushing against a tight converter. From 2600rpm-4000rpm your truck is probably real lazy. Then from 4000-6000 its a monster. That must be why you only race from a roll. Problem at the track is you launch at 2600-ish and you have to push through 2000rpm with low boost to get to its sweet spot. Then, 4000-6000 is over so fast, your into 2nd before you know it, but back at 3200-3500rpm. I had the same issues with the T56 and boost.
If you love your converter, then change the cam, if you love the cam, then change the converter and ex. A/R and plan on spinning it higher than 6000rpm.
