View Poll Results: Which would you choose
706
62.50%
Stock 799
0%
Milled 799
0%
Mill & CNC’d 799
37.50%
Voters: 8. You may not vote on this poll
706 or 799 for LY5?
Old 08-03-2023, 11:16 PM
Default 706 or 799 for LY5?
I am putting together a LY5 to swap into my dads 84 C10 and I’m not sure which heads to use. When I got the motor some one had taken the original heads but I do have a set of 706 and 799s that I could use. I don’t know they history of either set so whichever ones I use will get a trip the the machine shop. I just looking for suggestions on which heads to use. Motor is stock bottom end LY5 with 222/232 .550/.550 112 lsa cam, .052 head gaskets, gen4 truck manifold, long tubes, 3200 stall, 4l60e, 3.73 gears. Best gas I can get around here is 91 octane. Street driven toy, not a race car and not used for towing
Option 1: stock 706 heads = 10.3:1
Option 2: stock 799 heads = 9.9:1
Option 3: milled 799 heads
Option 4: CNC ported & milled 799
local machine shop recommend using the 799 and not milling them because that would be stock and would work just fine (true), they also quoted me $750 to do a clean up mill and vale job (sounds high to me). For $150 more I could take them to Texas speed and have them CNC’d but would I notice any difference on a 5.3?
Old 08-04-2023, 07:46 AM
shakenfake's Avatar
Received 1,276 Likes on 973 Posts
$750 I think is probably the going rate. I would consider a mill and cnc job though for the $150 more
Old 08-04-2023, 04:31 PM
smokinlmm's Avatar
I’d run the 799’s and have them milled and valve job. That would make it more snappy down low.
Old 08-04-2023, 09:50 PM
shakenfake's Avatar
Who tf is seriously choosing 706 heads???
Old 09-07-2023, 12:32 PM
Drspencer's Avatar
Those who recognize that the 7hp gain at 6,000rpm is less valuable in a 4500lb truck let alone the additional $300 in cores....lol.
Old 09-07-2023, 06:34 PM
shakenfake's Avatar
Awesome, HP that is barely felt seat of the pants.
$300 core charge huh?
Old 09-07-2023, 06:49 PM
Drspencer's Avatar
Another Texan thinking the world is just like the bubble around him. Lol. And are those U-pull prices? Have you been outside? Lawd, I’ll pay someone $100 to pull a set of heads.
Check marketplace. 799/243 heads are $400 in most places.
Old 09-07-2023, 06:51 PM
shakenfake's Avatar
Have you ever used car-part? These are auto recyclers so they pull everything u-pick up.
Marketplace sucks *****.
Old 09-07-2023, 06:53 PM
shakenfake's Avatar
Here is Florida just for you sweetie.
Old 09-07-2023, 10:53 PM
makes children cry
_zebra's Avatar
looks like you ran a compression ratio calculator... cool, but did you check dynamic compression differences between the stock LY5 cam / 799s and your cam + whatever heads? that looks like a relatively healthy bump stick with a converter to match, so the SCR gain of 706s might get you back closer to factory DCR, and a port & valve job would open them up enough to flow nice good for a N/A truck.
Quick Reply: 706 or 799 for LY5?
